Following the API example: Writing nodal data to a file (https://help.autodesk.com/view/MFIA/2021/ENU/?guid=Moldfl...
E.g.: in the example in line 53: Set Coord = StudyDoc.GetNodeCoord(Node)
How can I get more information about the members of this StudyDoc object?
Thanks for your help
Generally Moldflow API reference information is available such as:
In Synergy, top-right corner, to the right of the question-mark ("?"), click the pull-down arrow and select either:
Solver API Reference.
> Synergy API Reference.
tcode and tcodeset Reference.
Object GetNodeCoord is in Synergy API Reference.
Now, GetNodeCoord returns a vector object containing the node coordinates.
Xcoord = Coord.X
Ycoord = Coord.Y
Zcoord = Coord.Z
You could read this out from example script you provided link to.
Hope this helps.
Berndt
