Exporting Temperature Distribution Results with Node Coordinates in Moldflow
kola4FNSB
kola4FNSB
Is there any method to export Moldflow analysis results, such as the temperature distribution of a part?
I tried using the .XML export, but it only outputs the nodes and temperature values.
What I really need are the node coordinates along with the temperature results.
adevadkar
Hello @kola4FNSB,
You can get the nodes coordinates from other macro, just combine the nodes data and temperature results for respective nodes.
For writing nodal data to a file use given link for reference.
Writing nodal data to a file
Thanks & Regards,
Anirudha D
(If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
