Hello
ISO 294-4 defines terms and measuring methods for processing shrinkage. Shrinkage is defined as the difference between the dimensions of the tool
and those of the molded part at room temperature. It results from the volume contraction of the molding compound in the injection mold as a result of cooling, change in the aggregate state
and crystallization. Shrinkage is measured according to ISO 294-4 after storage for 16-24 h in a normal climate (23 °C, 50 % r. h.). Shrinkage is also measured by
influences the geometry (free or restricted shrinkage) and the wall thickness of the part. In addition, the position
and size of the gate, the processing parameters and the
the storage time and temperature play a decisive role. The interaction of these different factors makes it difficult to predict shrinkage accurately.
( Extract from: Ultramid (PA) main brochure of BASF )
The table shows that even unreinforced polyamides do not shrink uniformly parallel and perpendicular to molecular orientation!
Since shrinkage is dependent on too many processing parameters, I would approach the required level, the tolerance, step by step, at least 2 steps! See also BASF publication
hope the information will help you
