Cool FEM
Hi, I am trying to perform a COOL FEM study to evaluate the effect of the cooling lines (modeled as beams), mold block (from themold wizard) , and mold inserts (imported CAD geometry) in the cooling time of my molded parts.
I would like to know the correct sequence to perform the study, because first i imported the cad geometry of my part, meshed it, then added the cooling lines and meshed them. Finally added the mold insert and created the mold using mold wizard and perform the mold mesh, but I got error 1900136.
I checked that there were no intersections, non-manifold etc. I proceed to use the stitching tool as recommended but it does not recognize surfaces. I made a first mesh of the mold, then used the stitching tool and make the mesh again (having everything visible, water lines, mold insert and cavity) and it works until I run the analysis and I got a warning 312065 saying that my beams are not touching any mold surface.
I know it must be a mistake in the steps I am following, any recommendation of what is the best way of the sequence of steps I should do to perform this study correctly?
