Autodesk Moldflow Data Fitting 2018 is not opening .MFR Files
Message 1 of 12
I cannot open mrf files with Autodesk Moldflow Data Fitting 2018, do you know what is wrong? Am I suing the correct software?
Replies (11)
Message 2 of 12
mppkumar
Hi @Anonymous
suggest to use Moldflow communicator to view MFR files
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
Message 3 of 12
Thank you Pradeep!! 🙂
Do you know were can I get this software from?
I am trying to download the software from Autodesk site page and it has the Mold Flow Data Fitting Instead. Look the the attached screenshot. I downloaded the data circled in red.
Oscar Martinez
Message 4 of 12
mppkumar
Yes... you are right....the link in this location is not for Moldflow communicator
It's for Moldflow data fitting, which helps in creating UDB files
can you please update below link to install Moldflow communicator?
M P Pradeep Kumar
Message 5 of 12
mppkumar
Hi @Anonymous
you can get the Moldflow communicator installation files along with Moldflow insight software itself
if you are not using Moldflow insight and only using the Moldflow communicator for reviewing the results, try to contact your local Moldflow technical support or reseller to get the software
M P Pradeep Kumar
Message 6 of 12
Hi Guys!!
I do not have MoldFlow Insight in my computer, I received the mfr file from one of my Suppliers, they are using MoldFlow and I just receive the results.
So I will try to conctact my Local Technical Support here in Mexico. However would like to have Autodesk Team updating the site page to have the correct software in the link that they are sharing with the users, It is in case Mexico Office is not responding to my request as soon as I need.
Sorry for al the inconveniences!!! and thank you so much for your support.
Oscar Martinez.
Message 7 of 12
ethaya
Hello @Anonymous,
Good day!
Use this link to download Moldflow communicator; http://download.autodesk.com/us/moldflow2018/Autodesk_AMDF_2018_English_Win_64bit.exe
Installation guide and other stuffs are here; http://www.autodesk.com/products/moldflow/communicator-viewer
Hope this content could help you.
Best regards,
Ethaya
Message 8 of 12
mppkumar
Hi @ethaya
this link is not for Moldflow communicator, it downloads and installs Moldflow Data fitting (check the link, you have shared AMDF_2018_English_Win_64bit.exe")
actually that is his query... it installs Moldflow Data fitting, and he try to open MFR file in that.
M P Pradeep Kumar
Message 9 of 12
raalteh
Just so all know, this is in the queue (and has been in the queue) to be resolved.
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
Message 10 of 12
mppkumar
Thanks Hanno
once it's resolved, please do post
M P Pradeep Kumar
Message 11 of 12
raalteh
Hi All,
This issue has now been resolved:
Hanno
Hanno van Raalte,
Message 12 of 12
mtrujil1
Hi Oscar, sorry for my late response, im Mf user, if you need  support to open or read some analyzes i can bring support to you.
please contact me directly.
Regards
[email protected]
