Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Audi report Default Unit of measurement
1 REPLY 1
bschofieldLGPLU
45 Views, 1 Reply
I am starting to use the Audi report wizard for the first time. I have noticed that the units of measure will automatically switch to metric for the report slides.
Is there a way to change this default, to either keep it to the units being used in the actual study or to show both metric and standard?
Thanks!
1 REPLY 1
bernor_mf
in reply to: bschofieldLGPLU
@bschofieldLGPLU
The report generator is based on a script.
The report uses script:
TAPEbyAudi.vbs
In folder:
C:\Program Files\Autodesk\Moldflow Synergy 2025\vendor\tape
It set the units inside the script:
Synergy.SetUnits "Metric"
Dim FS
Set FS = CreateObject("Scripting.FileSystemObject")
Dim SynergyGetter, Synergy
On Error Resume Next
Set SynergyGetter = GetObject(CreateObject("WScript.Shell").ExpandEnvironmentStrings("%SAInstance%"))
On Error GoTo 0
If (Not IsEmpty(SynergyGetter)) Then
	Set Synergy = SynergyGetter.GetSASynergy
Else
	Set Synergy = CreateObject("synergy.Synergy")
end if
Title = "TAPE (Semi Automated Presentation Generator)"
Units name could be, "English" or "Metric" .
To change units:
Synergy.SetUnits "English"
To get system units this could be used.
Synergy.GetUnits
So, some changes of code could probably make this run as you intend to.
Do not forget to make a backup of original TAPEbyAudi.vbs before changing the code.
Unfortunately I have no example code, as "Metric" is my active units.
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
