About clamp force calculation
05:20 PM
- Mute
- Permalink
- Report
Dear experts
I'd like to ask a question about the calculation accurate of clamp force
sometimes when I check the result of clamp force, i found the max. clamp force is much higher than actual clamp force
for example
I can produce product on 800ton machine, but in moldflow, result indicate me should use more than 1000ton machine
I am feel confuing
and someone told if we add actual process to simulation analysis, it will be more accurate, i am not sure
could you explain the problem?
thanks a lot in advance
Ian
