Would like the option to modify the size of valve gate Glyphs
Users have requested the options to be able to resize the various glyphs in Moldflow.  Specifically, the option to resize the valve gate glyph.  When working with complex models, the valve gate glyph can get in the way.   It is possible to make it so that the valve gate glyph size can be edited like it can be for anchor planes? (holding shift and scrolling with left mouse button).
2 Comments
PascalGosset
I agree with you.
I don't know which other "Glyphs" you think about, but this possibility should be also applied to the Injection Cone.
Moreover, the color difference between a Valve Gate Glyph selected or not is hard to see.
Please, change that.
jim.mcguire
I further suggest that the element representing the valve gate should be able to be displayed in a "normal" way.  Now, when the layer containing the valve gate beam element is set to "Show as Axis Line Only", all other beam elements behave as expected, but the valve gated beam element continues to be shaded, thus, obscuring the node the user may want to see.
