stl file export from moldflow
currently we could export stl format as warped shape.
request to consider export as stl format as unwarped shape ( before warp). so that we can compare both stl files.
Note: currently we can export .udm file from moldflow. should have option to export .stl format would be helpful.
4 Comments
bernor_mf
@vasyabc
there is an option in Export > Model to export to ASCII .stl.
It will write triangles in stl format.
Could this help?
Exporting an ASCII model file
Berndt
ethaya
Hi @vasyabc ,
In addition to Berndt’s [@bernor_mf] method for exporting, there’s another way to export an unwarped STL file.
Navigate to Export > Warpage Mesh/Geometry and set the Scale factor to “0”. Please refer to the screenshot below for more details.
Does this look good to you?
Ethaya
vasyabc
@bernor_mf : Thank you very much. I could find This option for DD mesh only. couldnt get for 3D mesh.
vasyabc
@ethaya : This method worked. i could export both unwarped mesh and warped mesh. thank you very much.
