relative coordinates in create beams
in the command "Create beams" there's no option to use "relative" for the end coordinate.
This option is available for "create line" and is very quick and helpful.
To directly create beams you need to copy, paste, modify the first node coordinates or to offset the first node.
Regards
Michele Segato
1 Comment
ramon.looijen
Hi Michele,
I also noticed this a couple of days ago. That's why I started to create curves, assign a channel/runner/dimension property to them and then mesh all curves into beams at once.
Do you know why there's a separate "beams" function?
Best regards,
Ramon
