possibility to reopen variable speed valve gate
when doing a sequential analysis, it would good to have the possibility to re-open the variable speed valve gate.
in the current version, you can only open/close it 1 time
Regards
Cédric
1 Comment
This would be a nice enhancement, as it can be helpful to more closely simulate some molding situations where opening/closing the valve gates multiple times would be used.
Maybe consider adding the ability to have multiple open/close stages where you are able to set a uniform open/close pins speed? (set up the open/close profiles once, and apply it for multiple open/close stages?) However, I understand this could bring in some difficulty due to the length of time changing within each of the open/close periods.
Kristen
