Overlapping XY plots from different studies
When I compare different studies from the same project, it is easy to compare some results and quite difficult to compare others, such as XY plots ("clamp force" and "pressure at injection location" come to mind).
Right now, the data have to be exported to a text file, then imported into a spreadsheed and finally they can be plotted into the same plot for comparison.
Adding an option to overlap XY plots from different studies inside Sinergy would speed up the comparison.
Best regards
Andrea
1 Comment
I agree with Andrea's suggestion, its would be really easy to compare different studies for XY plots in a single plot/graph.
Currently I am doing the same thing.
I found another solution for this:
I copy the Fill time Log in as a text file and then import it in excel file and plot a scatter graph to compare different pressures/clamp force v/s Volume so as to have a better comparison if the fill times are different.
Prasad Mahajan
Technology Administrators
