Option to change Occurence number at a time
There much be an Option to Change Occurrence number to multiple beam elements/ tri or tetra elements of different property type in one instance.
For example :
If I need to assign occurance number of one quarter of layout, which having beam lements of different size and type(i.e cold runner, hot runner, cold gate etc) & having tetra elements or tri-elements. I can't select all at a time and assign one value of occurnace number. I need to select each type & assign occurance number separately. I.e if it have 4 different type of elements. I need to repete the task 4 times.
Instead of this, there must be option to change occurnce number of all the selected elements( beam or tri or tetra elements)at a time. & vice versa.
1 Comment
This is much needed request, this will add robustness to software, as well user will get rid of time spent in this operation in just one click compare to present ~50 clicks.
Please implement!
Mayur
