Moldflow API: Class MaterialPlot : to be able to set Temperature and Pressure for XY-graph.
This is regarding creating a XY-graph of material properties in Moldflow API:
Rheological Properties (Viscosity) and PVT Properties.
When creating a MaterialPlot, a XY-plot, you could use members such as:
DefaultValueRangeX
DefaultValueRangeY
ValueRangeMaxX
ValueRangeMaxY
ValueRangeMinX
ValueRangeMinY
This always gives 4 values for Temperatures (Viscosity: Shear rate vs. Viscosity) or
5 values for Pressure (PVT: Temperature vs Specific Volume)
Sometimes you would like to plot one or two curves in the XY-graph.
Enhancement request:
Add the options:
1) To be able to set Temperatures (1 to 5 curves) or use default in Viscosity XY-graph.
2) To be able to set Pressures (1 to 7 curves) or use default in PVT XY-graph.
Berndt
