Log File Regenerator
We run into this problem occasionally.  Sometimes the log file will either skip a large chunk of information (fill and/or pack tables) and sometimes it says "analysis aborted by user" when we kill the analysis, make a change and relaunch before the log file was cleared.
Since the results exist regardless of a complete log file, is it possible to either create something to regenerate the log file?  If not, then I my question would turn into a bug fix request on something that's existed for many years: Have the log file clear completely any time you tell it to delete the results (this doesn't always happen).
1 Comment
Another example:
This was run today.  The analysis finished through warp, but when I look at the log file, this is what I got (see below).  The log file stopped right after v/p switchover and started the warp analysis.  I have results, but the log file is messed up.  I wish there was a way to regenerate this so that everything is filled out properly without me having to launch this 5 hour analysis all over again.
