Summary
The possibility to create a box in graphic area to make a annotation on result.
Problem
When you did a note in results, some times is difficult to describe the exactly point where will occur something wrong.
Solution Proposed
You create a annotation tool, like a box that you can put a mensagem and link to a Node or local in the model. And this box follow the model in graphic Area.
I think this will be good in two situation, first in ASMI or ASMI to create a results or MFR file and when will revise the result in Communicator.
