Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
in DOE include multiple material option
If we can include multiple materials as a variable we will  be able to study the effect of material properties also on the quality criteria. It will really help.
1 Comment
M.Brassel
Sure, that would be an interesting option, though materials normally differ in various properties.
Even for the very simple example of temperatures it would be hard to investigate the effect of melt temperature or mold temperature, if you use a material with different recommended temperatures.
But if you consider the different effects concerning pvT, shear rate and viscosity it will be even harder to compare the effects.
