With the Modifier File it is really easy to apply specific changes in process Settings to a original sdy-file with the studymod command.
Therefore it is necessary to create a Modifier file like shown in Autodesk knowledge base:
http://help.autodesk.com/view/MFIA/2016/ENU/?guid=GUID-F757D920-F5C8-4B08-B45F-1DA7F6CB4A5A
Problem: I have to generate it myself , and I dont see the settings ive done in the original sdy-file.
it needs time and because of creation of specific changes can quickly cause errors because of the Syntax.
Solution:
Option in Synergy to export a XML "Settings-Modifier-file" from original sdy-file with complete process Settings.
Proc. Setting changens and finally generating of new study variants could be performed fast & easy.
