Examine Tool Text Size
I often use the examine tool, in both the Mesh tab and results tab, to display exact values locally when creating plots for a report. I typical use PowerPoint and like to place text boxes or multiple plots on the same slide. In order to do this I mush shrink the plot containing the examine boxes. Typical this makes to boxes so small they are no longer readable. As fair as I know, there is no current way to enlarge the text of the examine tool so when shrunk they remain readable.
1 Comment
Sometimes, when the zoom to apply to the image is not very big, this can be solved by zooming out the part and then using the examine option. It is not a perfect solution but sometimes it works.
