Default (user defined) folder templates
Projects can at times get very large with different models, materials, process settings and phases of tooling development. Would be a nice feature to be able to select from a few standard (user defined) folder set-up from templates while starting a new project or just allow definition of a standard set. The 'Organize Project' process helps but not always in a way that makes things clear and easy to find later.
Example
Task window
                -Imports
                               -Models
                                -Feed System
                                -Cooling System
                                -Mold FEM
                                -Final repaired
                -Analysis Trials
                                -DOE
                                -MW
                                -Gate locations
                                -Gate Runner Tests
                                -Flow Leaders
                                -Process Options
                                -Material Options
                -Reports
                                -Images
                -Final Approved
1 Comment
bernor_mf
I became a bit curious if a macro could do this.
Almost...
But it cannot move folders, it has to be done manually.
Maybe an acceptable workaround?
A fix in Moldflow API would help to be able to sort and control how and where subfolders are created.
Berndt
1) Default result from macro
2) Manually sorted
