Show only
Search instead for
could you please explain in more details how this request is different from what is already offered by the "Minimum part frozen percentage at ejection temperature" input value?
For example, if the customer wants the cooling time target to be that the cooling should end when at least 50% of the thickness is below the ejection temperature, they would input 50% in that third input box which you have shown here. If they want it to be based on a different temperature, then they just need to change the temperature value in the "ejection temperature" input box.
