Compression surface property plot to be created from Mesh Diagnostics tool
Thermoplastics Injection-Compression Molding
The "Compression surface property" plot is written by solver when first intermediate result is written.
The Compression surface property plot should be possible to created in Mesh Diagnostics tool
Request: Add Compression surface property plot to Mesh Diagnostics tool
Note: And if you set solver parameters "Dynamically update results display during analysis" to No,
the Compression surface property plot will not be written until end of analysis.
Need some improved options here.
Reference: Thermoplastics Injection-Compression Molding
Might be valid for Reactive Injection-Compression Molding as well.
And it might also be valid for Thermoplastics Compression and Reactive Compression Molding as well.
Berndt
