Currently we can only see temperature residual results if the cooling solution converged, but it had some difficulty with a few elements. It would be helpful if we could get this result even if there is no convergence so that we can know where to make changes to the mesh in order to work towards convergence. It's frustrating when a cooling analysis has not converged after several hours and then you have no feedback on what areas need to be cleaned up.
It would be great if it showed this result while it's solving and updating it at each iteration. That way we wouldn't have to wait hours for the solution to not converge before we can see what areas of the mesh need cleanup.
