We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Collapsed folders as default
When opening a project, all folders in the task pane expand fully by default.  In a project with a lot of studies, this can be a bit of a nuisance.  I usually have to collapse almost all the folder to get the most recent info visible within the window.  If the folders could reopen in the state (collapsed/expanded) in which they were when the project was closed, that would be ideal.  At the very least, making the default have a project open with all folder collapsed would be an improvement.
8 Comments
raalteh
Would sound like something for a user preference.  Other comments are welcome.
raalteh
Status changed to: Comments Requested
M.Brassel
I would like to see something like this for the results of a study, too.
Yes, please make this idea into reality, but again make sure that when you implement these changes please allow to expand desired number of folders, becuase most of the time i have study files that i needed at some point of time in different folders & i want to compare these studies, so i need to see multiple folders at a time to locate my study files.
So just dont restrain/limit to expand only one Folder at a time.
Mayur
Please implement it.
First thing to do after opening a project: Collapse all folders.
After that you can see the newest study.
Frank
dorinc
Hi Everyone,
Can I ask which version of Moldflow you are using, and whether you are using Insight or Adviser?
I have just tested this issue in the 2016 version of Insight and I see that all the folders are displayed in whichever confiuration I left them last time.  It remembers the last state of the folders in the Project Pane.  However, I can see that in some earlier versions the folders used to appear expanded by default.  I would be interested to know if anyone with 2016 is still seeing the behaviour of the folders appearing expanded by default (unless that was the state you left the folders in when you last closed the project).
Caroline
Principal User Experience (UX) Designer - Moldflow Products
Hi Caroline,
you are right. There is no issue in MPI 2016.
I think it´s OK.
Frank
raalteh
Implemented in 2017. Smiley Happy
