automatic link between mataerial data set and recommended default solver
To improve result accuracy for instance material data has to be fitted.
Beside pure material data the chosen process setting parameters do have signifcant influence.
For instance, to calculate fibre orientation several approaches are available as FulgarTucker, RSC model with spec. Ci etc.
This makes it obvious that a link between material data set and process setting resp. chosen solver setting is required!
I request to implement such a link to make it possible for material supplier to announce for which solver/process setting a specific material data set is fitted, resp. which solver is recommended.
1 Comment
raalteh
This idea has been requested by a few material suppliers in the last few years. Traditionally we have interpreted the the fiber solver settings as 'solver parameters', not a material parameter. This change is beind concidered though.
