Problem:
When the feed system of a part is not modeled and the gate location is placed directly on the part, the thermal conditions and the conditions of the flow front are not always quite clear. That's why at user meetings it has been recommended to always place at least one beam element between gate and part. In the beam element the boundary conditions for the flow are clear and the diameter of the part-beam connection is defined (which is not always obvious when placing a gate with specified diameter on a 3D-Mesh depending on mesh coarseness).
Solution proposed:
Automatic insertion of a beam element on a selected node when setting an injection location directly on the part. The beam element has preferably to be perpendicular to the part surface (if flat) or with definable orientation (if not flat).
Thanks for consideration.
