Auto Assign Property name based on Dimension/thickness/value
Hi Colleagues,
Would be great if the property names are assigned automatically depending on the dimension/thickness/value.
This would be helpful in selecting and identifying/modifying the dimensions easily when we select entities by property.
Also another advantage would be avoiding creating multiple properties with same values (more number of properties assigned with same thicknesses)
It would make someone lazy in manually modifying the names as mentioned below but would surely help for quick editing.
Current scenario:
Example:
For Midplane mesh:
Trias as assigned name as "Part surface (Midplane) (default)#1"
Idea:
Trias should be assigned as "Mid_2.0mm" if the thickness is 2.0mm
Same should be applicable for beams,curves etc.
##Refer images attached
