Alignment preview line
Current Situation:
at the moment we have to choose two alignment nodes and one node which should be moved.
You have to try if the selected alignment nodes are ok as movement reference. If not you have to hit undo after moving the node and select another pair of nodes. Especially in case of large distances between the nodes it´s really hard to estimate the final position of the "node to move".
Suggestion:
Add preview line between alignment nodes!
This makes it easier to evaluate if the chosen alignment nodes are correct BEFORE hitting apply.
Greets,
Andreas
