Add Result properties in Options with user defined
Its time consuming method to change the properties of result every Analysis completion.
There should be user defined PROPERTIES option in RESULT which is in APPLICATION OPTION.
3 Comments
rick.schneider
Can't you already do this with the "Save properties of current result" option?:
http://help.autodesk.com/view/MFIA/2017/ENU/?guid=GUID-39298E4B-98DE-4058-84D6-475297930CA0
prakashcheyyar
@rick.schneider Yes.. But I need a properties setting for each results. "Save properties of current result" option is applying to all results..
PascalGosset
This option already exists. There:
Result / Properties / Save Defaults / Save Properties of Current Result
Except it does not work as we want.
It does not save the settings of each result.
I ask myself how time took the developers to take into account our demands.
I would like them to let me know when they read this reply.
