Ability to open Logs file from job manager
I would like to add the ability to open Logs file of a job that is running without having to open the file itself.  Important as 3d files get larger and larger.  At times I do not want to open the model due to the amount of RAM required if I am already near limit of RAM.  I see this often during cooling analyses.
5 Comments
raalteh
Status changed to: Accepted
Understood
raalteh
Impelemented in Moldflow 2016
bernor_mf
see on-line help for Insight 2016:
View analysis logs without opening the study
lothar.weber
But it does not work in 2017?!
New IDEA?
BR
Lothar
bernor_mf
@lothar.weber
It works when a project is open, and right-click over study and select "View Logs"
2017: View analysis logs without opening the study
The option to select "View Logs" from the new job manager in 2017 is not available.
This should be re-introduced, to be able to "View Logs" from the new job manager, as pretty handy, and no need to open a project to view status of log.
So a "new" idea...
Berndt
