Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Study and Task window out of screen in moldflow advisor. How to dock again?
2 REPLIES 2
756 Views, 2 Replies
Dear Sir,
Its Urgent I am working on my research, accidentally my study and task window's upper part just go out of screen. Its not docking again and not fully showing. I have a lot troubled with that in getting results. please help me, I re-installed the advisor but nothing happened. see attachment.
regards
Mahmood Siddiqui
2 REPLIES 2
nordhb
after an unistall, you normally need to reboot machine before installing again.
If you are having odd issues with directory access, results access, as well as general usability concerns and need a quick fix without  having to go through the entire reinstallation process. A clean registry does just this, by cleaning out the registry and reconfiguring the installation to default settings and removing any configurations that may be causing those issues.
See this article:
Running a Clean Registry in Simulation Moldflow Products
You can also seach Autodesk Knowledge Network:
http://knowledge.autodesk.com
Hope the cleanreg resolves your issue.
Berndt
Berndt Nordh
in reply to: nordhb
Hi Berndt,
Thanks a lot brother,
problem solved. .  by cleaning registry. No need of uninstall this time.
Regards
Mahmood Sid
