I have recently upgraded to Moldflow Advisor 2017. I noticed they have a differential shrinkage output. Can someone please explain if this output is different from the deflection output. If so, could someone explain. It has been identical to deflection output in every analysis I have conducted so far.
Looking at the whats new Moldflow 2017 page (link below)
Solved by bernor_mf. Go to Solution.
This is the main warp result:
Deflection, all effects result combines differential cooling, differential shrinkage and orientation effects to show the final part warpage.
The results contributing to warp:
The reason for having the single variate deflection of cooling, differential shrinkage and orientation effects is to understand what is contributing most
to deflection result to focus on right solution.
Basically to isolate the cause of warpage.
So if Deflection, all effects result = Deflection, differential shrinkage, it seems as differntial shrinkage is having the most contribution to your main deflection.
If you add cooling, is should be different.
Hope this helps.
Berndt
