I did a machine translation of your question:
“Hello, I am a user of Adviser Moldflow 2012. I want to know how to change the direction of ejection. Me offers the software manangement continous Z!”
This definition is by design of software.
The pointing to injection side will always be in Z positive direction.
Moldflow Adviser shows arrows pointing to injection side.
This orientation is used by the Runner Wizard to automatically create runner system.
The projected area is in XY-plane, which is used for clamp force calculation.
You need to rotate your model, the “change” the ejection direction, how it points to injection side.
Select command Geometry, to find rotate command.
Now, you still can run analysis and build your runner system manually.
Be carefull interpreting clamp force result, as projected area is calculated in XY-plane.
Hope this helps.
Berndt
Berndt Nordh
