Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Issues
3 REPLIES 3
266 Views, 3 Replies
Issues
Before I describe the issue I will say that my system is totally up to date, latest drivers etc so please do not say it is a driver.
Now I got that out of the way I will describe what I am trying to. I have created a text file in stl format and I have the import function.
I dragged the cube into the workspace and I have re-sized it so that it is a slightly larger that the text. This is to placed as a plaque type file to personalise a 3d file for printing
Now when I try and move them together the workspace goes blank on the cube in the top right goes to a pink colour with a few lines in it. When I move the  mouse away from meshmixer it comes back, when I move the mouse back over meshmixer it goes.
Issues
3 REPLIES 3
MagWeb
MagWeb
Seems to be a graphics openGL crash.
GPU drivers need to support Qt5 (the framework MM is built on)
You might try this:
Shut down MM.
Rename meshmixer.ini to meshmixer2.ini (just to have a backup)
You'll find meshmixer.ini at:
Windows: C:\Users\User Name\AppData\Roaming\Autodesk\meshmixer.ini
(NOTE: AppData is hidden by default, so you might have to enter that path manually or choose to show hidden files.)
Mac: ~/.config/Autodesk/meshmixer.ini
(Note: .config is hidden by macOS defaults, so you might need to set macOS to show hidden files)
>>> MM will write a default ini on its next launch.
Maybe this fixes your issue.
If NOT:
Run MM. Before trying to load or doing something in MM:
Go to MM's Preferences (via menu) and disable ShowViewCube on its General tab.
If NOT:
Run MM. After loading any object :
Optional: Go to menu/View and enable ShowPrinterBed (if the bed isn't visible).
Look at the dropdown box at the upper right in MM's window.
If there's something like "NoPrinterSelected" open the dropdown and activate some printer (just to set one).
You now may hide it via View menu now.
____
That're things which fixed similar issues.
There seems to be something wrong with support of NVIDIA Quadro GPUs. What graphic card are you using?
Gunter Weber
Triangle Artisan
You might try this:
Shut down MM.
If NOT:
If NOT:
____
Gunter Weber
Triangle Artisan
in reply to: MagWeb
My setup:
i9 9900k, 64 Gig ram, RTX 2080 ti
All drivers are up to date.
Thank you for reply, I will try them next time I run it.
My setup:
I have tried all that and I am still getting that blanking, it happens when I want to combine files to make one. As you can imagine what I have been saying when I am about to click on an image and the workspace goes blank. I have finally managed to get them combined but on looking in chitubox one item did not align properly due to the workspace going blank with only a grid for company. It is not an intermittent problem as it happens all the time
