Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How to thin a face mask
3 REPLIES 3
776 Views, 3 Replies
Hello, I'm trying with all tricks to thin the model of a face mask, to make it printable.
I tried to group faces and than extrude negative. Also I created a dublicate and then tried to substract.
All didn't work.
Any suggestions, what to do?
It is this mask from thingiverse:
https://www.thingiverse.com/thing:515615
Thanks a lot!
Labels (1)
3 REPLIES 3
MagWeb
GenerateFaceGroups at Mode=EdgeAngle, AngleThreshhold at 53 and SizeThreshold at 50 gives a single face group for the front of this mask.
In SELECT select this group by double click.
Hit I to invert the selection and X to discard the mask's back.
Again select the front group and run Edit/Offset to build a new thickness (Note: You might need to set the output size first in ANALYSIS/UnitsDimension)
Gunter Weber
Triangle Artisan
in reply to: MagWeb
Thanks a lot, that worked easy after your instructions.
Could you please advice me shortly how to export it really smooth. When I export it as an stl or obj it gets quite edgy, as it doesn't have enogh polygons. How can I change the quality?
MagWeb
I would do such refinement on the front only (file size reasons).
So after you set the new thickness select the front surface again and run Edit/Remesh. Set RemeshMode to RelativeDensity and make sure that BoundaryMode is at FixedBoundary. Now rise Density to its max.
Accept and run Deform/Smooth on that selection too.
If you still need more triangles repeat the process.
Gunter Weber
Triangle Artisan
