Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How do I fill a hole in my model?
1 REPLY 1
Nicolai.sondergaard
20200 Views, 1 Reply
I have an issue. I have cut a model in two, using boolean operations. Unfortunately it turns out, there's a hole inside the model. I'm having some issues fixing this.
I've tried the inspector/auto fix but the surfaces are there, as they should, so it does nothing.
You can see the issue here:
1 REPLY 1
Boolean cut a interior cavity.
To get rid of it go to SELECT. Double click somewhere on the interior cavity's surface > this should select this surface totally (for it is surrounded by a face group).
Now there are two options:
Either discard that selected surface by hitting "X" on your keyboard plus running ANALYSIS/Inspector to close the resulting hole,
or, with the  interior surface selected, run Edit/EraseAndFill using Replace/FillType set at FlatRemeshed.
Gunter Weber
Triangle Artisan
