the documentation says meshmixer will import OFF files, but I tried to import the sample file given in Wikipedia, and I get "error opening file: cube.off" with no further information provided.
(meshmixer 3.5.474 on MacOS Catalina)
For reference, here's the exact contents of the file
OFF
#from wiki page
# cube.off
# A cube
8 6 12
1.0 0.0 1.4142
0.0 1.0 1.4142
-1.0 0.0 1.4142
0.0 -1.0 1.4142
1.0 0.0 0.0
0.0 1.0 0.0
-1.0 0.0 0.0
0.0 -1.0 0.0
4 0 1 2 3 255 0 0 #red
4 7 4 0 3 0 255 0 #green
4 4 5 1 0 0 0 255 #blue
4 5 6 2 1 0 255 0
4 3 2 6 7 0 0 255
4 6 5 4 7 255 0 0
Solved by cellocgw. Go to Solution.
Solved by MagWeb. Go to Solution.
MM doesn't support per face colors which are in this example file.
You need to remove these informations in the lower section to get a basic .OFF :
OFF
8 6 12
1.0 0.0 1.4142
0.0 1.0 1.4142
-1.0 0.0 1.4142
0.0 -1.0 1.4142
1.0 0.0 0.0
0.0 1.0 0.0
-1.0 0.0 0.0
0.0 -1.0 0.0
4 0 1 2 3
4 7 4 0 3
4 4 5 1 0
4 5 6 2 1
4 3 2 6 7
4 6 5 4 7
Gunter Weber
Triangle Artisan
