Smooth Boundary rounds sharp corners
Is there a way to prevent Smooth Boundary rounding sharp edges? I know this is common behavior, as noted in the help file, but I'm trying to figure out if there is fix for this, or a workaround I can try. Screenshot attached of a typical condition. I'm slicing objects that have some nice sharp corners, but S.B. puts a dimple along that crease.
If I remesh there with more tris, it still rounds them.
You can preserve sharp edges using temporary slim face groups.
To create a group at a sharp edge set a higher CreaseAngleThresh (prevents selection on the other side of the edge) and select a region at one side of the edge (bigger than the BorderRings value you want to use in SmoothBoundary. Convert the selection to a group (Modify/CreateFaceGroup). Now doing SmoothBoundary with PreserveGroupBorders on a different selection, where the selection border crosses the edge through the group, the edge stays as it is.
lower edge saved by a grouplower edge saved by a group
Thank you, this works great!
(wish list: Would be nice if smooth boundary had a sharp edge threshold slider built in)
