- Mute
- Permalink
- Report
Hello Meshmixer users!
I was wondering if one of you could help me to try to convert my model into a solid so that I can 3d print it. The first model I print will be like a test and will be scaled at 1:20, being 17 mm thick. The final model will be seperated into different parts, being a 1:10 scale with the same thickness. The problem I am having is that my model is only a surface and I do not know how to convert it to a solid. The model was made using Fusion 360, but I thought that perhapps it can be fixed using Meshmixer. I have asked on several forums for help, but I have only gotten suggestions to start over or turn to Meshmixer. My model together with a 1:10 stl file is located on my Grabcad.
Grabcad: https://grabcad.com/library/my-car-7
