Need Help with Plane Cut and Separate Shells
rene.wenus
Observer Observer
rene.wenus
Observer
Observer
Hello i have a Problem and im searching 3 Days for an solution but i dont find anything that works.
I have different STL files but always the same problem.
I import the STL in Meshmixer and first i make a Analyse/Repair to the Model. I need more Plane Cuts and Pins for printing. So Next step i select a section and make a Plane Cut. After this i go to edit/separate shells. Now i want 2 shells in the object browser but i become 90 shells. If i sort them and combine, after the next cut again i become x many shells. I hope you can imagine my problem and help me.
PS excuse my english.
greetings Rene
Check if your source mesh if composed by several not connected shells doing some test SeparateObjects.
  • If this already results in several objects consider to join them to a single  watertight object (ie. running EDIT/MakeSolid or joining the objects via BooleanUnion).
  • If MM  finds only one shell (or two in case of a hollow object) your cutting plane cuts it several times (e.g. if you do a vertical cut in a "S" shape). In this case (e.g. if you want to cut on the upper intersection of the S only) you need to run a selection based PlaneCut: Run Select and select the region where the cut is restricted to. Run Edit/PlaneCut inside SELECT.
On noisy it may happen the a global cut cuts tiny "peaks" of a tangent surface. This case run ANALYSIS/Inspector before SeparateShells and dim down the SmallThresh slider to detect only these small peaks.
If you do not want or an not combine loose pieces: Instead of doing a global separate action (EDIT/SeparateShells), there's also a selection based Separate: Navigate to a view along the cut done before and run SELECT. Click on empty space near the former cut > a red line will be drawn. generate a polygon roughly including one half but not touching the other. Now hit E to expand the selection to get one half selected totally. Now run EDIT/Separate inside SELECT.
rene.wenus
Observer
Observer
Thank you so much that helps me a lot. Make Solid was the right way for me.
