Modifying .stl file found on Thingiverse
reachmeplace
Message 1 of 31
reachmeplace
Hi, I'm new to Meshmixer. I downloaded an. stl file from Thingiverse. I now want to modify it by making the "knob" part of the crank 1/2 the size it is and make that same "knob" a little longer.  I tied to upload the .stl  (33kb) but I get an error message it's not the correct file type? Here's a screenshot of it in MeshMixer. Here's the  link https://www.thingiverse.com/thing:101313 Thank you!
Replies (30)
Message 21 of 31
reachmeplace
Hi Andrew,
I'd like the crank handle "arm" (which reaches up which is placed in the
hole to crank the device) to be very thin - the hole is about 1/8 of an
inch (the width of a Papermate 1.o M ballpoint "stick" pen.
The height (length) of the arm to crank to about about 3.5-4 inches.
Thank you so much!
Message 22 of 31
hfcandrew
I need ALL the parameters, in millimeters.
// Diameter of nut in mm
nut_diameter = 100;
// Depth of nut in mm
nut_depth = 15;
// Side wall thickness for nut chamber in mm
side_wall_thickness = 5;
// Length of arm in mm, from center of bolt to center of handle
arm_length = 222;
// Length of handle in mm, the length protruding from the crank
handle_length = 100;
// Diameter of handle in mm
handle_diameter = 20;
Message 23 of 31
reachmeplace
The default settings all work well except the crank "handle" (arm) needs to
be a lot thinner.
nut_diameter = 30;
nut_depth = 15;
arm_length = 100;
handle_length = 50; So, MAYBE this sgould be 100 instead to be longer???
handle_diameter = 20; MAYBE this should be 5 so it's thinner - about the
width of a Paper Mate 1.0M ballpoint stick pen
/* Hidden */
handle_radius = handle_diameter / 2;
nut_radius = nut_diameter / 2;
nut_cyl_radius = nut_radius + side_wall_thickness;
include ;
difference() {
union() {
cylinder(h = nut_depth, r = nut_cyl_radius);
translate([arm_length,0,0])
cylinder(h = handle_length + nut_depth, r = handle_radius );
linear_extrude( height = nut_depth)
polygon(points =[
[0,-nut_cyl_radius],[arm_length,-handle_radius],[arm_length,handle_radius],[0,nut_cyl_radius]]);
linear_extrude(height = nut_depth) {
hexagon(nut_radius);
Thank you!!
Message 24 of 31
hfcandrew
here
Message 25 of 31
reachmeplace
What changes did you make in OpenScad to export the file as a thinner crank handle? I can't see that for the finalized .stl in OpenScad as it will only open scad files? I had tried earlier today opening the crank handle in Openscad and deleting the crank handle and typing in 5 but I saw no changes either once I typed in the 5 nor when I exported the file as an .stl. Thank you ever so very much!
Message 26 of 31
hfcandrew
I did nothing different than what I have said and shown via the video
  1. Set the parameters as required
  2. Click 'Render'
  3. Click 'Export as STL'
I have no explanation as to why this is not working for you.
Message 27 of 31
reachmeplace
OK, thank you.
Message 28 of 31
reachmeplace
Hi, as a newbie I'm not sure if posting an Openscad questionhere is approgpriat so my apologies if I've offended anyone.
If there is a better forum for OpenScad questions I would so appreciate you pleas shrare a link to that forum.
Openscad seemed like an easy to use application and the 1st time I used to make an object taller and thinner  it worked by just typing  in new numbers. After that, when I wold type in new numbers  it never changed the look of the object. I even uninstalled and reinstalled but that made no difference.
I’m trying to just widen this .stl file I found on Thingiverse
https://www.thingiverse.com/thing:3131119
Poker chip
by That_sweet_1_fps October 01, 2018
https://www.thingiverse.com/that_sweet_1_fps/designs
It’s a poker chip but I wanted to make it wider. It seems to measure 1.5 inches wide now but I wanted to make it 1.75 or even 1.85 inches wide.
How can I easily (best) widen this file using OPenscad?
Thank you so much!
Message 29 of 31
hfcandrew
I feel like you are confused on what OpenSCAD and Meshmixer is.
Message 30 of 31
You need to understand the difference of formats which describe a body by some math functions (CAD files) or via some mesh of triangles. This difference is similar to the difference of pixel- and vector based 2D image applications. It's hard to edit a photo made of pixels with vector graphics tools.
Your source file, a STL is a mesh format so Meshmixer is the right tool and I gave you the HowTo do this in Meshmixer here.
No problem if you ask questions on third party applications. We'll try to give you an answer - if we know a solution. But here aren't the experts on those apps...
Message 31 of 31
reachmeplace
I probably am! I download OpenScad which world the 1st time to modify an
image but then didn't.
I thought Meshmixer was a completely different software program which I've
never used.
OpenScad seemed user-friendly for a newbie?
Thank you.
