meshmixer tools not working, red lines
Why do I keep getting these red lines and meshmixer tools don't work (ie. extrude, smooth boundary, and several other tools)
Red lines in MM highlight non manifold issues (more than two faces share the same edge or a "spinning off" face is connected to a closed surface by a vertex). Such issues make most tools fail...
Did you get this result using MM tools before (if yes what was your workflow?) or did you import from another application?
I imported an STL file from blue sky bio
Can you post the file here (or load it to some file sharing service and send me the download link via PM).
I'll look into it.
