- Mute
- Permalink
- Report
Hi all,
I'm new to Meshmixer. I have an STL of mandible, segmented from a CT scan. Naturally, even though the outer shell looks fairly decent, the inside has holes from the non-dense part of the bone. My goal is to actually measure the volume of the entire mandible. I assume when I see volume in Analysis>Stability, it means the volume of the "shell/solid part", while I need volume of the entire space that the mandible takes.
What I'm thinking I need to do is to make the object 100% solid with no hollowness at all, then measure the volume. But when I try Make Solid, it still has hollowness inside. I attach a screenshot of how the hollowness looks like after Make Solid. How to make it 100% solid? Or alternatively, how to measure volume of the entire object (not just the "shell")?
Any help is appreciated!
