I had like to know how I could fill the holes in this model with Meshmixer
francoislibert
Message 1 of 10
francoislibert
hello, i have this stl file which has 3 tunnels in it as you can see in the attached images. I don't know how I can manage with Meshmixer to fill these holes. Can't face me inside the center of the model? Can someone help me. MANY THANKS
Replies (9)
Message 2 of 10
hfcandrew
Generate Facegroups>Select a large enough body and separate to get a better visual on your target body>Select the target body and discard>Combine main body back in>Edit>Close cracks>Inspector
(view in My Videos)
Message 3 of 10
francoislibert
Many Many thanks for you tutorial. I will try asap. Have a good day, F.
Message 4 of 10
francoislibert
Dear,
First, if you didn't see my answer, Many thanks for your help and the tutorial.
I just tried to import the same file but as you can see on the attachment, the edges and connections between rocket parts are odd and rounded ?
Can you help me ? Thanks,
Message 5 of 10
hfcandrew
Read the stickied post.
"That's only a rendering issue on a low poly object.
Press space to open the Hotbox and in its Mesh/Normals section click on the sphere in the middle.
Or: via menu File (Meshmixer in case you're on Mac)/Preferences> MeshNormalMode: set to FaceNormals"
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-67B222B0-56AF-4E89-8986-C8F591BAFBDD
Message 6 of 10
francoislibert
Many thanks
Message 7 of 10
francoislibert
Hi again,
I began today to try to modify my stl but when I try to Generate Face groups, nothing happens, no different colors on the different surfaces ???
Many thanks
Message 8 of 10
hfcandrew
Turn on the group colours
Message 9 of 10
francoislibert
Hi, I'm back to try your tutorial. When you say to separate with O WHY, on what do I have to click : on the Y for sure but which other key  from key board or mouse button ?
Message 10 of 10
hfcandrew
Go: Select (and make the selection) > Edit > Separate
The hotkey for 'Separate' is 'Y'.
