emmanuel-SMT
emmanuel-SMT
After several unsuccessful attempts and researchs on web, I post my question here.
Is it possible to export a mesh (one element into the Object Browser) into .obj file with .mtl and .jpg files ?
Thank you for your help.
Emmanuel
MM v3.5
Windows 10
If you created the mesh and its color representation in MM: No. MM does per vertex color only. If you want to export the obj with per vertex color you need to set the output format to "OBJ Format with Per-Vertex Color" in the SaveAs dialog. Same if you transferred texture to per vertex color using MakeSolid.
If the mesh came with a texture and you only did some modification: MM saves the obj along with a mtl and image file by default. Some tools like Remesh destroy texture mapping of course.
emmanuel-SMT
Hello MagWeb,
Thank you for your answer.
I usually import a texture mesh file and do some modification using among MakeSolid function before exporting. It seems that even if "OBJ Format with Per-Vertex Color" is checked into MakeSolid function, it is not possible to get a .obj file with its associated files (.mtl and .jpg).
Can you confirm that ?
Emmanuel
Yes, MakeSolid creates a completely new mesh without any UV atlas. It can transfer the texture to a different color representation (per vertex color) but texturing is destroyed. MM saves mtl and image only if there are intact UVs (means only if you didn't use a tool destroying UVs)
emmanuel-SMT
Hello Gunter,
Thank you very much for this clarification !
