enlarge stl file
enlarge stl file
wm_pm
enlarge stl file
wm_pm
Hi, Is there a way to make a stl file, for example, 1mm larger mit meshmixer
do not scale, but enlarge metric, for example 1mm
Not sure about what you mean by the difference between scaling and enlarging...
If you want to change the global size (all dimensions scaled the same way) use ANALYSIS/UnitsDimensions. Here you can set a metric value.
You can do the same on a object by EDIT/Transform while keeping other objects in the scene untouched. Here you can do a proportional scaling and non-poportional scaling (check UniformScaling in the tool's properties). There you can also set numerical values (clicking on the displayed numbers) ScaleX, ScaleY, ScaleZ is a factor the current size is multiplied. SixeX, SizeY, SizeZ ist the target length of the bounding box (World- or LocalBB depends on the setting in the widget).
Or do you mean extrusion to add a length while the rest of the object is not deformed? In this case (e.g to make a pedestal of a sculpture higher) you can use SELECT: Select the region to extrude and run SELECT/Deform/Transform) Here you can't put in a numeric value. But the Transform widget has a snapping function you can en/disable by clicking on the little S circle. You can set the snapping increments using the Up and Down keys on your keyboard while click and hold a transformation arrow. The A circle toggles absolute and relative distances.
wm_pm
I would like to enlarge a stl file evenly with a certain mm indication. for example 1mm.
when I scale, it is unevenly magnified. only if I have a sphere or a rectangle or something similar would it work with scaling. i have stl dates that are complex, when i scale, i have reached the maximum I want the value i want, but in the contours it is less then. I just want it evenly piled up, which is for example 1mm more material everywhere.
So you want to offset the surface?
There are three ways:
1. EDIT/MakeSolid in SolidType: Accurate allows to set a OffsetDistance (this is remeshing your object based on voxels. So the quality of the result depends on SolidAccuracy and MeshDensity). w
2. There's SELECT(SelectAll)/Edit/Extrusion with Direction set to Normal. This simply pushes the triangles a certain offset distance along their face-normals. If there are concave regions on your source, this will result in self-intersection (e.g. at the neck of the bunny):
3. There's SELECT(SelectAll)/Edit/Offset which pushes the surface a certain offset distance along their face-normals and remeshes after that to get rid of self-intersections.Thicken2.jpeg
If it comes to preserving hard edges all three attempts are limited.
wm_pm
Thank you very much 🙂
