- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I tried to do a boolean difference between the two files I attached: https://drive.google.com/drive/folders/1weCyobWeWMZ4IYkphndYJpZpRMxaIsbq?usp=sharing
I first created an offset of 0.2 mm on the true3.stl file to clear things off and then tried the boolean difference. However, meshmixer gave me a warning afterwards saying that "an unknown fatal error has occured", and parts of the resulting model has turned red.
I tried a couple ways to trouble shoot, including remeshing on both models and extruding the true3.stl file instead of offsetting that. However, neither way worked.
I'd appreciate any insights!
Viola
