IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
MD'09 didn't show the window dialog box while use "open" command
3 REPLIES 3
2242 Views, 3 Replies
dear all,
i got some unusuall error & i can't fix it till now unless i reinstall the software. it's annoying me so much
some command like "open" , "amfillet" , "amextrude" , etc then it's shown the window dialog box (see attachment "normal.jpg").
but in this case, it won't show the window dialog box (see attachment "error.jpg").
is there an options that i should be checked?
do you all understand about what i mean? (cuz, i'm not good in english conversation & i still confused how to explain this error). i'm waiting for your help
thanx,
Noel
3 REPLIES 3
RogerMollon
You need to set 2 sysvars, look up FILEDIA and CMDDIA in the Help system.  I can't say why they are getting set to 0 (zero), but you want them set to 1 (one).  On the command line enter "FILEDIA" then enter, at the prompt enter "1".  Do the same with "CMDDIA".
When you can, note when the dialogs go away again to figure out who's changing these system settings.
I hope this helps.
Roger Mollon
Forge - Strategic Tech Consultant - Novi
Autodesk, Inc. - Retired
dear roger mollon,
thanx for the solution. i thought it always should be reinstall to fix the problem (repair the installation can't fix it)
i hope there's someone can explain what was my mistake that unconsciously make it set to "0" without any notification. or, is there some commands to lock the sysvar, so whatever happened it can't be changed without open the lock .but  ... once again i say thank you very much. Smiley Very Happy
God bless u
Dear Roger Mollon,
Thank you for all, it was a problem for me too
All commands working with window in right click wasn't working,
Thanks from Turkiye, I'll try immediately.
