Why is Maya 2016 saved jpg darker than when seen in Maya
I created a model and then used textture mapping to put a image on a street light.  When I render a image in maya 2016 it looks fine but when I open it up in a email it looks darker
Replies (10)
pshwayka
When your render is done and you go to save the image, click on the settings box next to the Save Image menu item and make sure "Save Color-Managed Image" is selected...then save your image.
Ah,
Thank you very much - that did the trick
Smiley Happy
Kent
DanPym
Is there a way to apply that when batch rendering with Maya Software?
mspeer
Hi!
Render Settings: Color Management -> Apply Output Transform to Renderer
babu.rahaman
hi..i didnt find " colour management " at render settings ..plz can u send snap shot of it
babu.rahaman
i think ..Preference -settings-Colour Management- there check Apply Output Transform to Renderer...right
DanPym
If you don't see the option "Apply Output Transform to Renderer" in Render Settings you will have to activate Color Management and to do so go to: Windows>Settings/Preferences>Preferences then look for "Color management" and click on "Enable Color Management".
babu.rahaman
hi...unable to find Colour management  menu at render setting..how i can get it at render setting..i had attached screen shopt please check it
this doesn't work for maya software
gaboreturi
You've just solved it thanks
