Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
View point 2.0 not working
2 REPLIES 2
1449 Views, 2 Replies
Hey !
  I have installed Maya 2015 SP4 & I use very well.
     When I clicked the Renderer-->Viewport 2.0 Showing below massage in script editor.
Massage : -Warning: Viewport 2.0 is not supported by your current graphics configuration or graphics driver version.
 The application is reverting to the legacy default viewport, please correct your graphics configuration or set the "Default viewport" preference to "Legacy Default Viewport" to prevent this error from recurring.
I have attached some Images for your information.
Please Help me to solve this. Thank in advace.
Thank you !
   Viranga Andradi
 Managing Director
      VRGSOFTS
2 REPLIES 2
_sebastian_f
your gpu hardware and driver specs will help. without i would say the message is clear. your system doesnt support vp2.0
hilaire.gagne
Hi Viranga,
Few things for you to check ...
1) Look at the information displayed in the Render Status window when first launching Maya.  It will provide details as to what display profile Maya initially configured during start-up.
2) Verify you graphics card limitations using the ADSK Certified Hardware portal.  It should provide details on your graphics adapter and its compatibility with Maya.
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534
3) There are some limitations with the various Viewport Renderers; I have a thread going on about it here:
http://forums.autodesk.com/t5/shading-lighting-and-rendering/maya-2015-sp4-ext-1-viewport-anomalies/...
Hope that helps,
* EDIT *
Agree with Sebastian; likely a hardware limitations ... the links above should help confirm.
___________________________________________
DELL Precision T7500, Dual XEON Quad Core
48 GB RAM, 2x1TB SSD, nVidia GeForce 2080 Super
Windows 10 Pro (64-bit, 21H1), DirectX 12
Autodesk Entertainment Creation Suite 2022
